Will not boot, completely dead
It will not boot off DC adapter or battery. NO power LED when the adapter is plugged in. Adapter is good. Measured 19VDC on motherboard connector.
Это хороший вопрос?
Это хороший вопрос?
Thanks for the suggestion. I opened up the laptop and took out the mother board. I checked continuity of the switch. First couple of presses I got and open then I started to get a short. Inspected it and could not see a problem. I reinstalled the board and its powering on and seems to be working. I guess time will tell if the problem crops up again.
Был ли этот ответ полезен?
Awesome man.
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 759
2 Комментариев
Simplest solution be would motherboard failure then.
Could be other components on the motherboard to specify but I don't think fixing those would go very well unless you are an professional.
из Brett Johnson
Try without battery connecting to power supply
из Amily Grey
