The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
137вопросов Показать все
Can I use the test cable for display from S8 to S9?
The iFix it store sells a “Test Cable for Display” for the S8 phone
Galaxy S8/S8+ Test Cable for Display Assembly
I’m hoping to be able to use this on the S9. It seems to work, but I have some trouble some times.
Can anyone say if using the S8 cable for the S9 phone is completely nuts? or can you say that there should be no difference?
Thanks,
Santiago
Galaxy S8/S8+ Test Cable for Display Assembly Изображение
Продукт
$9.99
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I believe the display cable connectors are different so unfortunately that cable won't work.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
thanks, that is what I fear, even though I get it to work, it shows some strange behavior. Do you know how to identify the connector in order to buy one from a generic electronics store?
из
@titoalfaro What exactly is wrong with your S9?
из
@ajcooke01 oh, nothing. I make/hack-together my own novel displays, and I have been using the flexible screens of the edge galaxy phones so for my testing I use the cable. But I was not able to find a cable for the S9 only the S8. manually counting the pins, it looks like the connectors would work, but I was wondering if there was anything deeper going on that I didn't know.
из
Добавьте свой ответ
Santiago Alfaro будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 168
