Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
Dropped and display screen is different colors with lines how to fix?
I dropped my iphone 3g and the screen is sometimes white and changes colors and has lines at the right side but i can still hear it open and lock and i am able to take pictures. how to i fix it and if i need to replace the lcd how much would it cost?
Это хороший вопрос?
Оценка 20
10 Комментариев
did you check connector 1 and do a hard reset? press and hold home and power for 10 seconds then release buttons.... you never know it might work and save you quite a lot of money..
из
What if your lock button doesnt work?
из
what if the home button doesn't
work?
из
I have a question
I was on YouTube and my phone start glitching crazy then different color lines pop up on my phone I try to turn it off and cut it back nothing work HELP PLZ ASAP
из
Soooooo my phone fell today and it started to blink and some clear lines appeared on the screen. After I hit my phone w/my hand, it the blinking and the lines disappeared. I turned this off for it to "rest" for an hour. When I turned it on, the problem came back and this time nothing fixed it. Aparte from changing the LCD screen, what can I do to fix it. Pllllzz help!Thanks
из
Показать 5 больше комментариев
Добавить комментарий
6 Ответов
Выбранное решение
If only your lCD is having issues, you can try replacing that:
iPhone 3G Display
If it is both your LCD and your glass/digitizer that are broken, this is the part you would need:
iPhone 3G Display Assembly
The guides for how to do the repairs are linked on the product pages.
iPhone 3G Display Изображение
Продукт
iPhone 3G Display
$29.99
iPhone 3G Display Assembly Изображение
Продукт
$59.99
Был ли этот ответ полезен?
Оценка 6
Наиболее полезный ответ
I dropped my phone on the concrete and my screen turned colors with lines in it but I can still read words and go on it the screen is just blue what is wrong with it and how much to fix it
Оценка 8
1 Комментарий:
It's an iPhone 4s
из
I dropped my oppo and my screen has gone colourful I need help ASAP please
Оценка 3
1 Комментарий:
I was walking and put my phone in my waist went I take it out it is showing me different colors need help what should I do
из
My sister once threw my phone to the ground and apart from all the shattered screen, some colored lines appeared only at the bottom of the phone but it still worked. Then it fell again, and this time, the lines covered the whole screen. So my dad took it to check and they had to change the whole display; so they remove the screen and put a new one.
Оценка 2
So my phone is glitching and it has lines on one side and the whole screen is green and pink so I can’t tell what color are my apps and I don’t know how to fix it. HELP
Оценка 1
I dropped my moms Xperia xa2 Sony phone on my rock and concrete driveway and now the screen is showing colored stripes even tho I still hear the login sound when I login using my fingerprint I want a way to fix it w/o removing the screen
Оценка 0
Добавьте свой ответ
soccerplayer32489384 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 20
За последние 30 дней: 73
За всё время: 103,939
