led panel vertical lines and screen blinking
sony led model no kdl-32ex650 panel replacement cost
Это хороший вопрос?
Это хороший вопрос?
chauthmal20 you did not tell us why you think a new panel will fix this. Replacement panels are often more expensive (if they can even be found) then a new TV. To find a proper replacement you need to go by the panel bumbner not the TV’s model number. Open up your TV. You’ll find a white sticker on the back of the LCD. It will say LG, Samsung, Sharp or whatever manufacturer made that panel and then the part number. Use that number for an online search.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 204
This is a question for a local repair shop or manufacturer. This website is meant for fixing devices on your own. Unless if you’re asking where to find the part to replace the LCD?
из toreskey
