TV won't turn on red light blinks and screen flashes then turns off
How do I get my TV to turn on? It was working fine then we moved and plugged it back in and the red light blinks and Toshiba comes on the screen then it shuts off
Update (11/17/2018)
Model number is 49L621U
I tried the power reset didn't work
Это хороший вопрос?
31 Комментариев
Hi @meowmix7878 ,
Try a power reset and check if this resolves the problem.
Disconnect the power from the TV.
Press and hold the TV's Power On button for 30 seconds and then release. (the button on the TV not the remote control).
(If your model has a Power ON switch and not a push button, just switch it on for the 30 seconds and then switch it off)
Reconnect the power to the TV and switch it on to see what happens.
What is the model number of the TV?
из jayeff
The Tv model is Hisense it go's of and on showing the name of the Tv
из Ar Glyphikzzz
I need help please
из Ar Glyphikzzz
Hi @ Ar Glyphikzzz,
You need to supply the following information to get relevant answers.
What is the model number, not just the name?
Does the power light turn off or only the screen?
из jayeff
I tried all that what said to do its not working
из Ar Glyphikzzz
Показать 26 больше комментариев
