The Visual Land Prestige 10 is an internet enabled tablet made by Visual Land INC. This device page and subsequent repair guides will show you how to remove and replace the devices components.
66вопросов Показать все
How do I factory reset a Visual Land Prestige Prime 10ES
I can't remember my password. How do I do a factory reset on a Visual Land Prestige Prime 10ES?
Это хороший вопрос?
Оценка 4
2 Комментариев
Need help with se10 will not let me log in to.it says to use email for this account.yes I have hard reset it please help.
из
I forgot my password on my prestige prime 10se how do I get it to work
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
1. Turn off the tablet. Yes, completely off.
2. Press and Hold both the Volume Up and the Power button at the same time.
3. Keep holding the buttons till you see the startup screen.
4. Press Volume up five times when you see the Android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn’t work on this mode use volume up and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Был ли этот ответ полезен?
Оценка 5
6 Комментариев:
I have this exact tablet and it is practically brand new. I have some pictures and videos from Disney World in Florida with my grandsons. If I do the reset to factory settings, I will lose everything, right? My youngest messed with the login and password and it locked up. I’m talking 6 years ago. It has sat undisturbed since then. It charges up and turns on really good. What do I do? Anyone? Can I take it to someone?
из
Wow It worked thnx!!
из
Mine turns on and stays at where it says visual land prestige that's as far as it will go ???
из
My tablet screen went to the log on screen and requires a password. When I depress the buttons as suggested nothing happens just black screen.
из
No I couldn’t reset to the factory.
из
Показать 1 больше комментариев
How can I rest my password on visual land prestige prime 10 E S computer table
Оценка 1
2 Комментариев:
How can I reset my password?
из
It stocks at welcome
из
It’s stock at welcome
Оценка 0
2 Комментариев:
How can I reset my PIN on prestige elite 10QH
из
How can I reset my password if I forgot it
из
Forgot my password in visual land tablet
Оценка 0
Добавьте свой ответ
Kelly Drummond будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 24
За последние 30 дней: 67
За всё время: 5,654
