How to install Flex cable
ok so i need help installing the flex cable into those holders which hold the cable to the phone, the power button has some black holder which holds the power switch, and the vibrate switch as another too do any of you guys know how to put the flex cable into these holders i am having alot of trouble please help
Это хороший вопрос?
3 Комментариев
did the flex you purchased come with the metal parts attached to the end of the flex or do you need to take them from the old one?
из pollytintop
ps. if you have swapped rear cases sometimes the problem is the machining of the case and the flex isn't the problem...
из pollytintop
no the flex did not come with the metal parts attached the end, i just need to know how to put those parts to the flex cable
из Christian
