How can I enter to the service menu in toshiba 32hv10e?
TItle.
I’ve tried everything I was able to find on the internet.
Thank you!
Это хороший вопрос?
TItle.
Thank you!
Это хороший вопрос?
ronben20 until we know what you have tried, look at these solutions.
"Most Toshiba flat screen LCD and LED TVs use the mute button method for accessing the service menu. To access the menu, set the volume to minimum and press the "Mute" button twice on the remote control. Next hold the mute button down and press the "Menu" button on the TV set to launch the service menu. You can exit the service menu by turning off the TV set." If no luck with that you can always try this:
"Toshiba LCD Service Menu Code”
Press the {MENU} button on the remote.
Highlight the "Picture" icon.
Press the {9} {3} {0} {1} buttons on the remote.
{OK} button will access/navigate through modes
{VOL +}, {VOL-}, {P+} & {P-} buttons move through options and change values
To exit, press the {MENU} button."
Был ли этот ответ полезен?
Tried the mute button no luck
За последние 24часов: 0
За последние 7 дней: 16
За последние 30 дней: 57
За всё время: 21,421
6 Комментариев
Do you mean the BIOS menu?
из [deleted]
It's a TV so I think It's a service menu.
из ronben20
ronben20 save us some time about telling you something you may already have tried. Let us know what "tried everything" this entails.
из oldturkey03
I've tried those:
1.
Tried with {4} {7} {2} {5} too.
2.
Press and hold the {VOL -} button on the TV and the {9} button on the remote control for few seconds.
{CH+} & {CH -} buttons select options
{VOL+} & {VOL-} buttons change values
To exit, press the {MENU} button or turn the power off.
All the other solutions that I've found - need buttons that I don't have on my TV.
I only have VOL-, VOL+, CHA-, CHA+ and power button.
Thanks!
из ronben20
i want code of model l32l5865ea
из deyaa hekal
Показать 1 больше комментариев
