Is there any way to add a Firewire port to this Hp PC?
I have an HP 15-r011dx and I’m wanting to use my Canopus ADVC-100 to hook up to my old VCR to convert old VHS tapes to DVDs. Problem is: the Canopus requires a computer that has at least a Firewire 400 port. I’ve seen the firewire ports available to install for other PCs, I just have no idea where it would go on THIS PC. If anyone has any ideas I’d really appreciate the help. Thanks!
P.S. If all else fails w/the PC, I could always use my MacBook Pro which has a FW 800 port, so…
Это хороший вопрос?
1 Комментарий
Thank you @danj for your speedy response! I had a feeling this was going to be the answer, but I really appreciate knowing for certain. I am much more familiar with Macs than PCs so, again, thanks!
And I DO already have a mid-2012 MacBook Pro with FireWire 800 as I mentioned, so I guess I’ll be using THAT for this conversion process after all.
Also, thanks to @jayeff for anticipating my NEXT question about whether or not I could use a USB to FW converter. Seemed dicey, but thanks @danj for confirming my thoughts about that, too. Seems like when you’re in the process of converting analog to digital, the less weird interfaces the better, yes? :)
All the best! —TW
из Traveled Woman
