The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
My Memory Card Is Stuck In The Bay Backwards, Help!
The Card Is Jammed In The Area To Put It In, We Have Used Letter Opener Knifes, Tweesers, And More But Its Stuck, The Wrench Icon Is Showing, And It On A Gray Screen Frozen! Awnser Soon Before We Gotta Use Our Warrenty!
Это хороший вопрос?
Оценка 0
1 Комментарий:
I Meant Its Jammed In There Backwards
из
Добавить комментарий
Ответов (1)
hello Abthony Bonnano, my name is John and when i have an issue like this I would try to pry it out with tweezers or a pair of pliers that are electronic grade that are small pliers and try grabbing card long ways and rocking back and forth. the other option is to take the cam apart to access the card box from the inside of the cam. and force it out that way. but if you have a warranty you might want to use it because if you open the unit your warranty is voided.
https://www.amazon.com/iFixit-Precision-...
https://www.amazon.com/Linemans-Klein-To...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Anthony Bonnano будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 196
