Laptop Crashes with weird screenflickering if charged and used
The laptop crashes, makes weird noise and the screen flickers like on the picture. It seems like this happens after around 10 to 30 minutes of using it while charging it or having it plugged in general. It may also happen without charging it I haven't yet tried that for longer but it definitely doesn't happen as fast.
Thanks for everyone that tries to help
Specs:
Это хороший вопрос?
Оценка 1
1 Комментарий:
Try testing and checking on your computer memory,
you can use memtest app to test.
if there are multiple memory, suggest you remove all and test one at a time.
из
Добавить комментарий
