Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143вопросов Показать все
Missing screws for bottom of 2.5" drive, what do I need?
I replaced my SuperDrive with an OptiBay, but now I can't find the screws to hold the 2.5" HDD into the OptiBay drive sled. Are these the same as any other laptop HDD screw?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
According to which OptiBay adapter you got, it may not need the screws. Actually I've seen three machines come in that I had to remove the screws from the bottom because they were oversized and preventing the machine from closing properly. These have all been the Unibody models. So its according to how tight the fit is and which machine you're working on. Some, I've just used electrical or kapton tape to hold in place. Where are the screw holes in your adapter?
Был ли этот ответ полезен?
Оценка 4
5 Комментариев:
Good question, I don't remember exactly, but I seem to recall them lining up with several holes in the bottom of the HDD. The HDD has been bumped out of alignment before and I've had to open the case and re-seat it. Unfortunately, I lost my jewelers screwdrivers along the way, so I'm waiting for a new set to show up.
из
Hard drives have screw holes in the bottoms and sides
из
You know, I should have read that differently. These are the holes in the bottom of the HDD.
из
The Optical bay adapter (from iFixit) has two sets of screws in a separate package that you may have overlooked. I got one in today and was very pleased to find that they were completely recessed on the bottom and added nothing to the height. I was able to add a 12 mm hard drive to a 15" MBP pre-unibody that's not supposed to be able to take it.
из
I ended up doing something similar - I used some low profile laptop hard drive screws from a local businesses IT department. Thanks for your information and the help.
из
Добавьте свой ответ
JeremiahPeschka будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,736
