The Neato Botvac 80 was released 2014. Part number 905-0079.
3вопросов Показать все
Neato Botvac D80 issue.
I own 2 of these units (identical). By swapping a couple parts I have determined that the battery, and charger base are not the problem. Bad unit has no power at all. If I put it on the base to charge, Home button lights up green, tells me to turn the switch on (it’s already turned on, but I press ok anyways). Home button turns to amber (slow blink to indicate charging has started). After between 10-30 seconds, it changes to rapid amber blinking on home button and after about 3 seconds it shuts down, reboots and starts the process all over. Ideas?
Это хороший вопрос?
Оценка 3
1 Комментарий:
Hi Jeff, got the exact same problem. Figured it had to be a faulty on/off button so I swapped it for a new one, only to find out that was not it...Did you ever find out what the problem was?
из
Добавить комментарий
1 ответ
I just successfully repaired a Botvac D85 that had a similar issue. I connected my computer to the USB port and saw an error flash that said the battery was overheated. This caused the main board to automatically power off. The root cause for mine was the Fuel Gauge IC. It took a hot air station and some patience. You might give this article a look. http://www.robotreviews.com/chat/viewtop...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jeff будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 9
За последние 30 дней: 24
За всё время: 732
