Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
Это хороший вопрос?
Это хороший вопрос?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
Был ли этот ответ полезен?
It might be much easier to just buy a new cable:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 119
1 Комментарий
Hi. Maybe you could solder it but it won't be easy.
из Csendes Csaba
