Основная страница для телефонов Android.
33690вопросов Показать все
Can you translate chinese from Bluboo S1 screen?
Hello,
I came across this Bluboo S1 phone not charging and with a non-responsive touchscreen, I haven’t yet figured out a solution for these problems, but I am puzzled with the screen shown as you can see on the picture below:
Can anyone translate it to English please?
Это хороший вопрос?
Оценка 0
2 Комментариев
Your phone is stuck in 'factory diagnostics' It likely doesn't have Android OS installed.
из
@Dan Thank you for your post. It does have android running and it is not stuck in 'factory diagnostics', I just don't understand the language so I can read the options
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Go to Settings > General > Language & Region and tap iPhone Language. If this isn't set to English (U.S.), select that option from the list of other languages that appear and then tap Done. You'll then need to wait for a few seconds while iOS changes the language. Return to Settings > General > Language & Region.
@tomchai Do you know anyone that can help translate this or walk him through the fix?
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Paragon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 99
