The fourth-generation Ram pickup truck (called Dodge Ram until 2010) was introduced in 2008 for the 2009 model year and sold as the Dodge Ram 1500. The 2500, 3500, 4500, and 5500 models were later added to the lineup.
Random blower motor functions on and off
My 2014 ram 1500 blower motor randomly cuts in and out. I have changed blower motor and control switch and it’s still cutting in and out.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If you have changed the blower motor and control module, you likely have two remaining possibilities:
1: Your blower motor resistor has failed which can cause an intermittent connection as the resistor heats and cools.
2: You have a loose connection in your wiring harness. Check all the pins are firmly in place in the connector.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Aaron mclean буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,320
