Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
704вопросов Показать все
Can a BSOD Switch console charge?
Have a Switch console here that has a blue screen no matter what I do, tried a hard reset, tried connecting to a PC to use RCM and diagnose it that way, it just won't do anything other than show me a nice blue screen.
My question is, will the console charge in this state? My thinking is that it needs to be able to boot to get to the point where it can enable charging but right now, it just isn't at all. I only get the blue screen when its plugged in, when I unplug it the console dies.
I've checked the internal battery and it's completely dead. While connected to USB it does show 4.16v getting to the battery, I've not checked the current though.
Basically it seems like it is charging but the battery being totally flat has now died. I'm not sure if it's really worth replacing the battery as it has a blue screen, but maybe the blue screen is a result of the dead battery?
USB port and the charge related ICs seem to be behaving normally.
I should add none of the ingress indicators have activated.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi!
As far as I know the Switch won't take a charge if the battery runs flat unless you do the following:
1. Power the console completely off
2. Plug it in. It will turn on, wait for it to get to that blue screen of yours
3. Hold down the power button for 20s (I think, could be longer or even shorter), it will force a shutdown.
4. Leave it plugged in for a while, it will charge in this state.
Был ли этот ответ полезен?
Оценка 2
I have the same problem. It has a blue screen. But when I plug in the USB type-c it turns on still in the blue screen but it charges. I bought it like this off of eBay for $75.
Оценка 0
Добавьте свой ответ
joelwhybrow будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 3,079
