Panasonic Lumix DMC-FH20 — это цифровая камера с разрешением 14,1 Мп. Она относится к типу компактных камер («навел и снял») и доступна в черном, серебристом, красном, фиолетовом и синем цветах.
battery cannot be removed
after opening the compartment and releasing the lever inside the battery does not pop out as it used to and it can not be removed. how can it be removed?
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Выбранное решение
thanks very much for your help!
Был ли этот ответ полезен?
Счет 1
Наиболее полезный ответ
@sbba1618 make sure that the locking mechanism is fully engaged. Sometimes it helps to push down a bit on the battery and see if that releases it. If that does not work, use a pair of hemostats or tweezers and try to pull it out with the release lever engaged.
Замена аккумулятора Panasonic Lumix DMC-FH20
Счет 3
3 Комментариев:
thanks. i can not get something around the battery to grasp it as it does not move after release of the locking gear
из
@sbba1618 you may have to try to split the case and see if that releases the battery. It is possible that the safety latch has failed and stays engaged. This would of course involve a complete disassembly. Start with the posted guides
из
thanks a lot it finally came out I'm so happy:)
из
If your battery is older it may have swollen slightly, generally that's because you need to stop using that battery it's time to get another, AND the tweezers can work better if you warm the camera up, like put it near your body if your out so that there is less tug hassle. The swollenness of the batteries demonstrate that they are aged and need replacing.
Update (05/12/25)
The swollen batteries are a danger to health. Lithium ION batteries can explode, so try to remove and get rid of them safely.
Счет 1
1 Комментарий:
Adhesive tape may work to grab and pull (depending on the issue). It worked for me on a similar camera.
из
Добавьте свой ответ
s.a. буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 51
За все время: 4,013
