Руководства и информация по ремонту второго поколения североамериканской версии Honda Odyssey, выпускавшейся с 1999 по 2004 год.
Idling problems while driving or parking
i have a problem with my van-upon starting, idles higher than normal-in gear idles higher than normal-check engine comes on after s min. of driving then TCS light comes on when waiting for traffic signals-feels like i have foot on gas and brake at the same time.Upon parking-when put into park-idles from1100rpm to 2600rpm back down to 1100rpm in rapid succession.Wont quit doin this until i punch gas pedal to try and kick down idle for which is does then stalls.What sensor, what notorious part might be responsible for this?
Это хороший вопрос?
Счет 2
1 Комментарий
Any help would be a great help-contact me at gorski.john7@gmail.com if you could- a suggested price to the problem or part would also be great! Thanx
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
It could be your TPS (Throttle Position Sensor), MAF, or even a leak in your Intake Manifold (maybe a lose or broken hose to a cracked manifold), check to see if the MAF sensor is dirty or has too much oil on it. Do as Osvaldo said, get your codes read at AutoZone, Hey its free!
Был ли этот ответ полезен?
Счет 2
go to auto zone for a free computer readout
Счет 1
This problem could also be caused by a broken power steering pressure sensor wire. Check for a loose green wire near a sensor on the power steering rack. It often breaks over time and causes a fluctuating idle like you described.
When operating normally, the sensor increases engine RPM slightly to increase power steering pressure when the driver is turning the steering wheel with the engine at idle, such as when parking.
Счет 1
Добавьте свой ответ
John t буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 23
За все время: 4,504
