only keyboard replace on dell inspiron 17 5770
can you only replace the dell inspiron 17 5770 keyboard?
Это хороший вопрос?
Это хороший вопрос?
Raymond Bernard, yes it can be done. Download the SM for your computer from here It’s not easy but possible.
Был ли этот ответ полезен?
SM only covers palmrest/keyboard replacement. Not keyboard removal//install of palmrest. Welded in?
Yes, depending on how you define 'only'. The keyboard and palm rest are pretty much integral, you need to melt plastic tabs to replace 'only' the keyboard. I have replaced my 5770 keyboard. The repair manual is still (11/2024) available here: https://dl.dell.com/topicspdf/inspiron-1...
Essentially you disassemble the computer from the bottom. The manual explains the procedure step-by-step. For me, the hard part was popping the base cover, even starting at the corner as directed; it took more force that I expected. The second time I opened the case to upgrade the network card it went quickly.
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 1,158
1 Комментарий
Can you provide the service tag so I can find you the correct part?
из Alec
