The Lite Version of Huawei's 2017 P10 smartphone. Released in March 2017 it features a dual rear-camera setup developed in partnership with Leica. Equipped with 32/64 GB storage and in six different finishes. Model number WAS-LX1A.
28вопросов Показать все
Why is my device not getting on and only does when plugged in charge
hello guys my huawei p10 lite doesnt get on when i press the on button the only it gets on and keeps on restarting is when i plug in the charger, and sometimes display huawei eRecovery then it resarts after some few seconds. the charging indicator does not get on
Это хороший вопрос?
Оценка 2
1 Комментарий:
Hi. I don't fix phones but am just also looking for a solution for one of mine now.. It jus started doing the same.. Did you find a solution for yours or not, is the problem fixable??? Thinking about replacing the battery... Is it worth it??
из
Добавить комментарий
2 Ответов
Seems like a battery issue. It doesn’t want to keep a charge, so it’s time to change the battery (or change your phone in shop, if it’s still under warranty).
Был ли этот ответ полезен?
Оценка 0
4 Комментариев:
but i bought the battery recently it doesn't have six months
из
That can happen with everybody. Just got unlucky, whatever, fixing it and moving on.
из
oh okay thanks i will replace it
из
Good luck, dude. Godspeed!
из
If you are still looking for an answer , a solution might be USB Charging Port Charger. For me it was a short circuit in the charging port that was caused from the broken antenna cable. If that's not the issue then unfortunately it must be a motherboard issue.
Оценка 0
1 Комментарий:
My huawei p10lite fell yesterday and it is in erecovery mode..it cannot charge..what can be the issue
из
Добавьте свой ответ
Lapologang Matshelane будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 808
