The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
123вопросов Показать все
Apple Watch does not power on...
I have an Apple Watch 42mm Series 1 and just recently installed a new battery and a force touch sensor. I tried to follow the guide as closely as possible when taking apart the watch and later putting everything back together. After I sealed it all shut, I placed the watch on the charger and all it does is flash the Apple Logo and would not charge or power on. Now, I’m wondering if perhaps something is wrong with the connections?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I would take it back apart and make sure you have the battery connected properly. An iphone will flash an apple logo then reboot endlessly with no battery present. The watch probably does the same. If the battery is installed correctly then you may have a bad battery. The battery on the series 1 watch can be a little tricky to get it plugged in all the way.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Roman Laktionov будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 130
