A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
battery only charges if removed and reinstalled
battery only charges if its removed and then reinstalled into the phone ( wall charging) ordered a replacement battery and it does the same thing . But replacement was supposed to be new but has a manufacturer date of Jan. 2015 bad battery or phone Thank You
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Have you tried other chargers? It sounds like you are having some type of grounding issue. The manufacture date is probably correct as the G3 is a very old phone and not produced anymore. I would maybe buy another battery from another supplier just to rule that out.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
lance buell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 66
