Repair and support for the third generation of the Flip portable speaker by JBL.
70вопросов Показать все
1r5 disconnected. Have to push down to make work .
I diagnosed that my 1R5 inductor is not detchted but loose. It seems I have to push back toward the wall to make the speaker work. But if I let go the speaker stops working. This was caused by a drop. I have a Jbl flip 3.
How do I keep the 1r5 to stay pressed down so my speaker works.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
hey austin,
as a general recomendation i would suggest to look if you can see if the connector to the main board is still correctly soldered in place and to see if you can solder it back on or replace the 1r5 if that doesn’t fix it just stay safe and good luck
-M
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
austin johnson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 489
