Repair guides and support for phones manufactured by Lenovo.
284вопросов Показать все
My Lenovo A6600 plus phone won't charge and turn on
Before it became totally dead, I used my cellphone even though it’s low battery and charging(I used it because I had important things to do with it especially in school). So this December I experienced when I charged it and saw it full, it became low batt when I used it in only a minute or an hour. Before I slept it was so lowbatt because I used it for our dance in our Christmas Partya and of course I charged it. But when I woke up, I checked it if it was full and I felt nervous because my phone won’t turn on or charge. It was important for me because it was a gift from my father. What should I do with it? Can you give an advice.I hope you can help me. Thank you.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Does it still charge? If it does, it might be an issue with the battery. If it doesn't, use a wooden toothpick to carefully clean out the charging port and check again. Might fix the issue.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jowana Glanccy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 226
