PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387вопросов Показать все
PS4 Controller is Dead and wont charge
I have an 20th anniversary PS4 controller that died. I was in the middle of using it and it just turned off and it will not charge or do anything. I have replaced the battery and the connection ribbon and that did not resolve the issue. I tried calling Sony and they will not fix it as it is out of warranty. I cannot simply replace this as a new one will cost $200+. Does anyone else have any other solutions?
Это хороший вопрос?
Оценка 1
1 Комментарий
what have u already tried to do with it? most simple solutions are some where online and repeating every step would be a waste of time.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
A new standard PS4 controller would be $40-$60 here
A new 20th Anniversary edition is $96 on amazon here
You could swap a standard controller’s board into your 20th shell, but I do not know how different they might be
Был ли этот ответ полезен?
Оценка 1
Hi. This video is probably help for u.
Didn't you think to buy a used? Or a replica?
Answer me if this the video is helped you!
https://www.youtube.com/watch?v=-HpDBMsj...
Оценка 0
Добавьте свой ответ
James Arrico будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 2,543
