iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Replacing screen, adhesive won't give, but screen moves visibly
I’m trying to replace the glass on an ipad air that I purchased used. The glass broke — nearly shattered — when it fell, in a case, about 18” onto a carpeted floor, so this is very likely not the original screen. I can’t get anything between the glass and the case, even after 2 min of the iopener or 15 min on a heating pad. There’s a spot on the left upper corner where the suction cup will adhere directly to the screen; I can see the screen bow out when I lift, but I get no gap even though the screen becomes visibly convex. Much more of this will probably break what’s left of the glass. Should I just let this happen and remove the pieces (screen is taped over), or is there a better way? The videos and pics I can find online all show what looks like a pretty easy release of the adhesive.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
A safety razor (nice and flexible, don’t try a utility razor) did the trick. Once the corner of the blade is under the glass (maybe 1/8 inch), a pick will slide right in under the blade.
Also, a helpful hint for using the iOpener at altitude: unless it has cooled to nearly room temperature, keep your reheat to a single run of 30 seconds in the microwave. I waited more than double the recommended time (around 25 min.) and the fluid started bubbling in the second 30 seconds, rupturing the iOpener.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jon Houck будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 75
