Model No. A1367 / 8, 16, 32, or 64 GB capacity
915вопросов Показать все
I Cant Shut down iPod Touch 4th Generation
So, I have a friend who has an iPod Touch 4 with 23 million minute lock glitch. Im no expert but I said I would at least attempt to fix it. So first thing was that I had to shut it down, but because the screen was cracked I couldn’t slide the slider to the end, so i searched on the internet. They said hold power and home button at the same time, I tried many times but all that did was restart the iPod Touch. I dont know what to do know. Please Help, Thank You.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Just wait with the device turned on. It will eventually die and then you will have it powered off.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Ill Try that, but I did charge i all night last night so umm...
из
Since the only way I know of to fix the 23 million minute lock is to completely restore it, you could just keep holding the power/home combination as you did before.
…or you could just wait for the device to die.
Оценка 0
Добавьте свой ответ
Kourosh Esmailian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 36
