The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Fixing the right earphone - only works with 7.1 (Hyper X Cloud II)
Hey everyone,
My right earphone stopped working. I have read the other threads but I still am not sure what to check for or how to fix it. Everything seems to be attached like the other images I’ve seen.
I’m pretty sure the damage is on the left side, as before it stopped working entirely I could sometimes get it to work by bending the main feed wire.
Could anyone provide me some specific guidance?
Thanks!
Here is a picture of the left.
Edit: It works if I use the USB dongle and turn on 7.1, which is very strange. But it won’t work plugged directly into my phone (no dongle, obviously).
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Lady Nightwinkle  “It works if I use the USB dongle and turn on 7.1,” in that case it is unlikely that it is the driver (speaker)or the wiring. If anything, it is an issues with the connector which is very strange. “it won’t work plugged directly into my phone” because it will require a different connector to be compatible with your phone.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
It used to work plugged directly into my phone, though. And my new headphones work plugged into the dongle with 7.1 on and off. So I'm quite sure the dongle is fine.
из
Добавьте свой ответ
Lady Nightwinkle будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 241
