Repair and disassembly information for the Logitech MX Anywhere 2S portable wireless mouse. Released in 2017 and identified by model number 910-005151, 910-005133, 910-005152, 910-005153, or 910-005154.
Вопросов 9 Показать все
My right click is stopped working.
I was using it casually when I pressed the button and it didn’t work and it didn’t click.
Это хороший вопрос?
Оценка 0
2 Комментариев
Hello, I have the same issue with the MX Anywhere 2 version, not the 2s. Would you happen to know what micro switches are used in the 2 version? I want to replace them but there is no info online about the type of switches used in this mouse.
Kindest Regards,
Rodrigo Solis
из
So I have the same mouse the MX Anywhere 2, and I opened it up and looked at the numbers on the switches and just ordered them on Ebay. To save you save you some time here is the Switch name and a ebay link.
Omron D2FC-F-7N(10M)
https://www.ebay.com/itm/5PCS-OMRON-Mous...
из
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
On 99% it’s microswitch. U can replace it .
Find this on your region
https://www.amazon.co.uk/Mouse-Switch-Mi...
U have help here on this website
Logitech Anywhere Mouse MX Micro Switch Replacement
Был ли этот ответ полезен?
Оценка 2
Hi @maxthegamer4548
Had you tried pressing on other buttons?
Had you test on another PC?
If you press and use a little force, does it works?
If it is under warranty, suggest you to send in for service.
Else….
you need to open up and try replacing the micro switch first.
Оценка 1
1 Комментарий:
I just bought 3 switches off of Ebay and replaced the right click myself. It just took some solder and a solder pen.
из
Добавьте свой ответ
Max Murphy будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 21
За последние 30 дней: 55
За всё время: 6,542
