The ASUS X751L is a large screen (17.3 inch) fourth generation i3 dual core laptop released in 2015. Identified by model number X751LX-DH71.
11вопросов Показать все
Power socket not accepting cable.
The power cable on my laptop has suddenly stopped pushing into the socket properly. It seems to push the fitting in the socket back so it will not enter the plug properly. I have checked a different charger but that is the same. I think it will possibly need a new socket. Are there any guides how to change it, I am having difficulty finding one.
Это хороший вопрос?
Оценка 0
1 Комментарий
Sounds like the plug itself has broken away from the board. This can happen if it was dropped or front stresses of having the cord yanked or pulled on. Replacing it would likely require some extensive solder work and depending on the damage to the motherboard itself, may not even be possible.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Luckily your model is one that can be replaced with a dc jack that is user replaceable and doesnt need soldering.
However, it sounds like you might have an issue with the plastic housing inside that holds the dc jack in place. In this case, do you happen to have experience opening laptops? They are all basically the same. You will remove the battery and all the screws from the bottom, then you remove the keyboard usually by tabs near the top of the keyboard and you unlatch the keyboard connector on the motherboard, then separate the top case and bottom case from each other and make sure you unlatch any cables that are still connected to the motherboard. This is a real quick and not very detailed run down, but if you are comfortable with tinkering with it, you can open it up with a little bit of effort.
If the dc jack is good and it’s just loose inside of the laptop itself, use some decent super glue to hold it back in it’s proper spot. I’ve done this countless times for customers with no complaints.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Hi @ronecc ,
Just to add to the good answer above, here's a link to the ifixit Asus X751L guide which may be of some help in gaining access to the DC-In jack.
Replacement parts are available online Just search for "ASUS X751L DC-In jack" to get results for suppliers of the part.
из
Добавьте свой ответ
ron eccles будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 217
