The Explorer saw significant exterior, interior, and suspension updates for the 1995 model year, losing all its exterior bodywork shared with the Ford Ranger.
Not starting when key is turned to start
Ford explorer has nothing to do with Mac Pro. Im looking for the reason my Ford Exployer just stopped turning on from one minute to the next. Is does not even turn over yet everything else is working but not the ignition
Это хороший вопрос?
Счет 0
1 Комментарий:
Do you have access to a multimeter? You first need to verify that your battery has 12.6 volts and then I can guide you further
из
Добавить комментарий
1 ответ
Ignition switch controls the signal to the computer to power the vehicle and make contact in the starter to engage the solenoid. Otherwise it is your solenoid on you starter
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Pyasotol буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 199
