Third generation Surface Pro tablet, released June 20, 2014.
123вопросов Показать все
How to test the battery pack before replacing it?
I have a dead Surface Pro3, presumably with a defective battery pack. After many months of looking at it I took the plunge, broke through the screen and have the battery tail with its connector free. The main connector tabs show zero volts but Im not sure if this indicated a dead cell or that I am not enabling a switch within the battery management scheme which is part of the battery pack.
Can anyone tell me if the battery tail should be at 7.5V standalone, ie how do I test the battery pack before trying to replace it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
In Windows 10 you can open a command prompt with admin priv and type powercfg /batteryreport /output "C:\battery_report.html
Был ли этот ответ полезен?
Оценка 0
no directly replace it, without doing any test, as you already said the battery is dead so there is no reason to test it, a dead battery could also harm your surface pc , so be cautious.
Оценка 0
Добавьте свой ответ
Tom Nicols будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 18
За последние 30 дней: 20
За всё время: 85
