Beats Solo 2 Wireless headphones are a wireless version of the Beats Solo 2. Released in 2014. Model number: MHNG2AM/A.
No screw holding inner carapace
I am trying to repair a pair of beats solo 2, as no sound was coming out of the right side. I’ve seen that this is a common problem, but when I opened them up I noticed that it did not have a screw on the inner carapace underneath the tape. It is instead held together with what appears to be 2 white pieces with a slit in the middle. Does anybody know how to take that apart?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Please show us what step on the guide you are referencing:
Beats Solo 2 Wireless Teardown
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Its not a battery problem, it is the other side of the carapace part connected to the other side of the battery (the part with the rubber parts you need to push through)
из
I also have this problem. There is no screw that I can see. The tear down above does not help.
из
Добавьте свой ответ
Adam Remaly будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 146
