Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1702вопросов Показать все
Why are the lights blinking and there’s is a clicking noise
My bottom freezer lg refrigerator started clicking. I notice that the light in the freezer blinks as it clicks. The produce light it blinking as well.
Update (01/31/2019)
This is a video of what’s going on
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
I am not super well versed in appliance repair so i’m sorry but I can help with some basic diagnostics.
  • Have you checked the freezer light bulb to see if it is replaceable? This could be end of life for that bulb
  • Can you tell if the two blinking lights are connected? try to find the door close switch for the freezer, hold it in with the freezer open and see if the light still blinks. does it stop blinking, blink in both spots, blink only in one spot?
  • Do both lights drawer and freezer blink in sync?
  • have you tried unplugging the entire unit waiting 10 minutes and plugging it back in? this is most likely not the issue but would be a good troubleshooting step.
The clicking comes from a relay turning on and off the light so that is not a separate issue. My guess is this relay went bad or there is a short in the system somewhere.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
The clicking and blinking are directly related and I don’t believe either have anything to do with the light bulbs. We’re you able to view the video? It seems to be Morse code!
из
I have the same issue and cant figure out what is wrong
из
Добавьте свой ответ
Tammy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 19
За последние 30 дней: 60
За всё время: 13,246
