First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130вопросов Показать все
How do I replace the middle frame on the touch screen?
I bought a replacement glass and digitizer for an iPad and it did not come with the middle frame. How would I go about taking the old frame off of the broken glass and placing it on the new glass?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
You certainly have your work cut out for you. Getting the front glass off of the frame is quite a chore, but lucky for you, we do have a guide for such a process.
NOTE: This guide doesn't show up in search results because we don't want to cause any confusion between front glass (which we don't sell) and front glass assembly (which is a much easier repair).
Good luck, and let us know how it works out.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
amanthey1979 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,438
