Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Replaced screen not working
Replaced screen. All works except about1” of left side.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
IPad digitizers should always be tested before install to rule out possible manufacture glitches. If it’s not been installed yet you may contact the seller for replacement. If it’s been installed already nobody will replace it, thus the only thing you can do is remove it and check the flex cable has been properly fit in position. iPads are not easy to repair and replacement parts are cheap but prone to give issues, especially if the housing has been bumped and not in perfect shape. Have a look at this great post by @refectio , it might help you sorting things out too.
After doing my repairs (battery and screen) I have problems
Был ли этот ответ полезен?
Счет 4
Добавьте свой ответ
Edward Lyzbicki буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 117
