Debuting in 2002, the first generation Sorento was a traditional truck-based body-on-frame SUV.
11вопросов Показать все
Door ajar light stays on even when car is off.
My door ajar light stays on even when car is off. Also the door ajar chime goes off CONSISTENTLY CONSTANTLY it never stops BUT only when driving !! Please help. I have pressed the sensor on all doors. The driver door is the only door that when pressed the car ajar light doesnt go off. Does this mean the switch is bad? Anything else to try before replacing sensor? Also a diagram of where it is at would be appreciated.
Thank you so much
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Just replace the door jamb switch on the drivers door. It's normally a bit of black accordian rubber that sits on the car side of an open door.
https://images.app.goo.gl/m2VLGnTkv5ty5A...
When door is closed it presses the switch telling the car the door is closed. You can test it yourself to see if it is the switch by pressing it in
Very cheap part from an autostore
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Anslee Carroll будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 17
За последние 30 дней: 84
За всё время: 2,432
