A detachable 2-in-1 tablet and notebook manufactured in 2016 by HP.
7вопросов Показать все
replace my digitizer screen now the screen won't light up
replace my digitizer screen now the screen won't light up but if I plug it on to a monitor i can see it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Did you disconnect the battery before installing the replacement screen?
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
No, I did not.
из
That usually means the backlight fuse has blown. Shine a flashlight behind the apple logo of the screen and see if it displays a image on the screen while it's on.
If yes the macbook will need to be taken to a reputable macbook repair shop to get it fixed.
Try reseating the display cable with the battery unplugged and see if that helps.
из
Thank you and have a good day.
из
I feel dumb, I thought this was a MacBook air sorry.
из
You may have just missed a cable. At least graphics card works as mionitor works.
Go over the steps again, slowly with good light. Some times the little ribbon cables can be tricky.
Оценка 2
1 Комментарий:
Thanks a lot.
из
Добавьте свой ответ
Hannah James будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 172
