The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Backlight stops working, intermittent. What can I do?
I have the MacBook Pro 13 RETINA A1502 2015
and the motherboard is at bottom.
Laptop works fine, then after a while, the screen goes out. I an see the screen if light is shown through the apple etc, so there is content, but no light. Then I open the back cover and press on the corner in upper right area where you see the display connection and also undo that clip and put back. Then the laptop works again for few days. Then light goes out. Is there some small part I can replace? or something I can do on that motherboard? I don't see any rusty areas or loose connections, it all looks fine but I assume a loose connection somewhere. Trying to solve without having to get new logic board.
Thanks for your help
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Maybe a part broken solder joint, sometimes a bump can do that, or it’s a failure in the backlight circuitry, not very common but nothing is really perfect on this planet, we reached the moon half a century ago and saw a shuttle bursting in the sky over thirty years later. Intermittent failures are the worst to deal with, but in any case it seems a board issue. You’ll probably need a logic board repair or replacement which, given today’s screen prices is not the worst alternative.
Был ли этот ответ полезен?
Оценка 1
maybe the ccfl light or whatever it is is damaged or you blew a fuse
Оценка -2
1 Комментарий:
Yes, whatever..uh..
из
Добавьте свой ответ
pcgeek будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 551
