Unable to read memory card
Phone does not recognize the memory card, sometimes it works but most of the time it doesn’t. Memory card is working in other phone and in PC.
Это хороший вопрос?
Это хороший вопрос?
It could be that your phone does not support a memory card of the size you are using. It could be that the reader is dirty, and needs to be cleaned or replaced.
Был ли этот ответ полезен?
Check your SD card reader.
Use a different USB Port.
Turn off the write protection of the SD card.
Restart the device.
Put your computer or phone to an idle state.
Format SD card to fix SD card read/ write error.
Regards,
Will
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 747
Sd card show nhi aa rha
Hai kya kre
из ashvajit sardar
Oppo f1s SD card not working
=== Update (01/18/2023) ===
из Ashvajit
из Ashvajit
SD card nahi aa raha hi
из morep5361
