My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
Это хороший вопрос?
Оценка 1
2 Комментариев
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
из
Hi @k12 ,
What is the model number of the TV?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
Был ли этот ответ полезен?
Оценка 1
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
Оценка 0
Добавьте свой ответ
Kier будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 10
За всё время: 861
