Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1199вопросов Показать все
0.2 inch Light stripe on the screen after dropping my phone
I dropped my phone, the screen didn't crack but I have this light on the side about 0.2 inch. Appended pictures.
Should I change a new screen or it’s a connection issue ? Anyone has any suggestion? thx!
Это хороший вопрос?
Оценка 2
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Hey Piper, it is possible that the LCD connection is slightly loose, I would suggest disconnecting the battery, and then reseating the LCD connectors, and then connecting the battery. If this doesn’t work, it is possible the backlight in your display may have been slightly damaged, and will require a new screen to fix. I hope this helps!
Best of luck, Alec
Был ли этот ответ полезен?
Оценка 2
Super powaaaa, my mom has the same issue but she calls it her light saber!!!
Оценка 0
Hi Piper,
Did you end up figuring out how to fix the light?
I dropped my phone and the screen didn't brake but now I have that same strip of light on the bottom of the screen. Hurts my eyes.
Оценка 0
You can damage the LCD and not the Digitalizer, which is what looks like happened. a new screen should fix it.
Оценка 0
I have a question my cell phone one day just stop working I cant get it to come back on.so I took it apart and theres a little brown mark on the strip that connects to the back of my screen what does that mean? If anyone could help me out with this that would be great thank u.
Оценка 0
Добавьте свой ответ
Piper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 101
За последние 30 дней: 399
За всё время: 26,727
