Released on October 25, 2015, the Afterglow Prismatic Wired Controller is an Xbox One controller produced by video game accessory company, PDP.
16вопросов Показать все
Why is my controller not turning on?!
I had one controller and that one suffered to water damage so then I got a new controller (but I'm Hispanic so I'm not rich so I couldn't buy another one after this one) so I had this new controller for about 3 months but then it just suddenly won't turn on. I know what ur gonna say “it's the cord" or “fix the cord” or “i had the same problem and it fixed by changing the cord” but that didn't work. I know this because the cord works with my phone and other devises so it should work with my controller. I'm not rich so don't tell me to buy a new controller. The controller won't even turn on so I can recalibrate it. The colors don't turn on or anything. Please someone help me, I'm 12 and can barely last without my Xbox.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The port on the controller has the bad connection. Try cleaning off the contacts. If that doesn't work, check out the micro USB connector repair guide.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
It's the controllers micro USB port.
I sprayed some electrical component cleaner in it, plugged it in and unplugged it multiple times (to get the cleaner to penetrate and clean the contacts) then wiggled the cord end at the port a few times, started working again.
I've even unplugged and plugged it back multiple times, works like a dream.
Hope this helps someone else!
из
Добавьте свой ответ
JKILLAH Gaming будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 9
За последние 30 дней: 19
За всё время: 2,613
