The second generation named the Freelander 2 (codename L359) debuted at the 2006 British International Motor Show.
7вопросов Показать все
My LR2 is completely dead and the battery is fine
I have a 2010 LR2. Yesterday I put the fob in the ingnition and the dash lit up and started going crazy. Afterwards the car was completely dead, the battery had died and when a new brewery was installed everything was fine except the car would not start. The dash displayed a error message for HDC (Hill Decent Control) system fault, system not available. No click, no grind just dead silence.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Hi @drrloringberry ,
Don't know the answer but thought that the info in this link may be of some help.
из
Добавить комментарий
1 ответ
Hi there!
In the engine bay, there should be a rubber button (orange or red) I don’t remember correctly. But try pushing it in. If you can’t try hitting it with a fist or a wrench and it should pop up and afterward just push it in. Don’t brake the button though! and try starting it again.
Let me know if that helped :)
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Randal Berry будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 1,189
