The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Battery is not charging
Dear experts
I recently received a MacBook Pro 2015 13” Early for motherboard repair. This board number is 820-4924.
Owner connected system to low cost Chinese charger and MacBook turned off and does not want turn on.
I found, than Q7130 is defective, so i replaced Q7130 and U7100. System turns on and work perfectly, But:
  • When system is turned off and connect charger, the system does not boot. I have to press the power button to turn on the computer
  • When system is turned on and connect MagSafe charger, computer does not want charge. In manager it shows me than charger is connected but does not charge.
So i replaced Q7155, D7105, R7105 and U7100 one more time but system does not want charge.
Any idea where can be problem?
Thanks
@refectio
Это хороший вопрос?
Оценка 0
1 Комментарий
Добавить комментарий
1 ответ
Выбранное решение
It sounds like a Smc issue, already checked PP3V42_G3H_SMBUS_SMC_5 ? As a rule of thumb I prefer to replace the ISL and the two mosfets at once or one runs the risk the faulty part burns the good one in a never ending loop.
@refectio
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
do you think U7100, Q7130, Q7180 one more time?
из
@honzo I doubt that it would solve your problem, symptoms seem to be pointing to an SMC related issue in my opinion.
из
can be damaged smc when connect fake china charger?
из
@honzo SMC itself is quite a robust IC that doesn't get damaged very easily by a bad charger also because there are other components in between, but it might happen. However resistors used by the SMC for current sensing or along battery charging circuitry or even rails may be damaged more easily. Continuity testing and resistors probing are often needed.
из
@arbaman after replaced SMC macbook charge, but when board cooled down charging stop.
из
Добавьте свой ответ
Tomas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 455
