The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211вопросов Показать все
Reset done, partition cache done still stuck on samsung log at start
I have factory reset and partition cache reset, and still wont load past logo on my Note II. Can I load a new OS and if so, please tell me exactly, step by step how to do it. My genius son moved to Germany and I have minimal tech skills.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You can load new software although you need to have some know how on what to do. It’s a big ask to have someone explain step by step. You might be better off taking it to a repair store and seeing if they can flash it for you. But if you want to give it a go you need to
Download Odin (Flashing software)
Find your correct firmware for your device (Google)
Download said firmware
Put your phone into download mode (Volume down + Home button)
Connect your phone to your PC via Cable
Open Odin with phone connected and import firmware into AP
Flash software.
Make sure you have everything correct otherwise you run the risk of bricking your phone.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Cindy Scott будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 26
