Not working- blue lights flashing
Suddenly during cleaning my v8 has been stopped and blue light start flashing. When I put into the charger the 2 lights are shining and one is flashing. What's wrong? Thanks!
Это хороший вопрос?
Это хороший вопрос?
Brand new same issue no help not answer phone omg horrible
Был ли этот ответ полезен?
DV6: blinking blue battery led or no led illumination at all. Replaced the battery - twice. Once with OEM, once with aftermarket. Same issue. Replaced the charger with OEM. Same problem. Dyson is just a crappy brand with crappy product.
The lights while it is plugged in indicate that the battery is charging https://www.dyson.com/support/journey/tr...
The light while it is unplugged indicates the battery needs to be charged https://www.dyson.com/support/journey/tr...
If the battery indicates a full charge while plugged in but immediately goes dead while unplugged, the battery has failed and should be replaced.
Same identical problem. New machine. Dyson sucks!
It doesn’t suck. That’s the problem.
It do suck same here, stoped working and this is a second one in 2 years and the last one!
it doesnt suck that bad
If your battery is broken, it is thankfully very easy to replace!
You can order a very pricey battery from Dyson, or try this one which worked great for me from iFixit:
There are several guides here on iFixit that should help you install the battery, but it is very straight foward.
Dyson sucks and their help centers https://support.dyson.co.nz/support/sv14... are not useful. Replacing filter and resetting Dyson and helped.
За последние 24часов: 17
За последние 7 дней: 87
За последние 30 дней: 435
За всё время: 75,136
1 Комментарий
Same issue ... nothing about this LED sequence in Dyson manual but after I opened the battery I’ve found a dead cell so I replaced the battery ... I’m trying now a non genuine battery with 18650 cells inside ... much cheaper and easy to find
из Catalin
