iPhone SE cannot be turned on after dropping to the floor
Hello everyone,
I bought iPhone SE that was dropped on the floor and it cannot be turned on.
I checked it already, and found that the battery was not functioning. After I changed the new battery, it can be turned on. However, it turned off automatically after 10-15 second. Two days latar, the voltage of battery dropped. Therefore, the iPhone cannot be turned off.
Today, I connected the iPhone to a DC power supply which was adjusted at 4 volt. The current showed at 0 A.
when I turned it on, the current changed to 0.18 A.
However, when I hold the on/off button in order to turn it off again, the current was changed to 0 A, and suddenly increased to 0.18 A again.
Does it has a problem on the button for turn on and off?
Thank you very much
Update 06.03.2019
It can be turned on. iTune reconised it.
It has an activation lock which showed in iTune.
I did already restore and update my iPhone.
After update, the first screen show “Hello press home to open”. However, when I press home button, it rebooted itself.
Sometimes, it turned itself off about 2-3 minutes later, when I did not press the home button. The battery status showed green color at first time. Then, it change to red color
Is it the problem from the logic board or the charging port (part for home button connecting)?
Update 08.03.2019
It did not turn itself off. However, it still rebooted when I pressed home button.
I changed already a charging port, but the problem cannot be solved.
Это хороший вопрос?
