Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Which glue would you recommend for glueing iPhone home buttons?
More than one type glue will be required depending on what you are repairing on your phone. I currently use B-7000 glue, which is mega strong, sets fast and will adhere to almost anything, but it is just too fast setting for some applications, so my question is what do you use for glueing:
  1. iPhone home button rubbers
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
b-7000 or E-8000 watch this video here, explained really well https://www.youtube.com/watch?v=xsF9jYUn...
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Cheers Tom, that looks like the one, reasonable cost, strong and slower setting times
из
Наиболее полезный ответ
I don't do many screen replacements mostly board work. But if I do have a screen to replace I use b-7000. I don't stick the camera brackets or home buttons
Оценка 2
3 Комментариев:
The camera brackets & home buttons usually have some adhesive left over. For the most part the proxy flex holds the camera brackets in place, but I have come across many home buttons that need glue
из
Which home buttons, Iphones ?
из
Yes Daniel iPhones. I often find the home button rubber has come away from the inside screen and there is a lot of dirt inside on the button and the rubber part has lost a lot of its adhesive, but still in good condition. Once cleaned, a bit of glue does the trick.
из
Добавьте свой ответ
Roland Chandler будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 93
